ViewSonic VP2030b 20.1" LCD Monitor Logo
Posted on Dec 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When turned on, monitor power light comes on for a moment and then goes out. Monitor eventually comes on after several minutes. The same happens if the monitor is left on but goes into sleep mode.
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
Answers
286
Questions
Helped
253583
Points
565
This is a common problem on these monitors. There are three or four capacitors in the power supply, three on the inverter board and anywhere from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been having problems before it was serviced. The longer the wait, the more capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not. As mentioned, it is a multi layer board so removing the old capacitors and the old solder can be troublesome. I would suggest you have someone experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
Priyabrata Das
Level 2:
Guru:
  • Expert 94 Answers
  • Posted on Dec 18, 2009
Priyabrata Das
Expert
Level 2:
Guru:
Answers
94
Questions
0
Helped
24465
Points
221
Check whether the power cable is ok ...
try to replace the power cable with a new one...and then try to start the monitor
2answers
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Dell 1704FPVs 17
Check you video cable ..if loose tight the screw..if still the problem presist try changing the video cable.
1helpful
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
Monitor image comes up, then blacks out, power still on
Hello David,
This is very common problem and is heat/age related, but It can happen to monitors that are no more than a year old. It is usually bad capacitors on on power inverter board. I just fixed two monitors with this problem. This problem is common across all brands. Look for several radial capacitors in a cluster on the power inverter board. If some are bulging or have a slightly domed top, they are the ones that are bad. I usually replace all the capacitors in this small cluster because some may be marginal. This is easy to do if you have a bit of electronics skill.
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
7helpful
LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
1helpful
6answers
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
2answers
Monitor not activating
Sounds like will need component-level electronic troubleshooting, probably in the power supply section.
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
