Sounds like a bad door switch,to replace the door switch you will nead to remove the body.first you nead to remove the two screws behind the control panal one on each side.next pull the panal forward and flip it up.next you nead to unhook the door switch.next you nead to remove the two s-clips one on each side.next you nead to pull the body forward and remove the body.now you con remove the two screws that holds the door switch on under the door next remove the door switch connecter from the body and install the new one.next reasemble unit
