I want to know How to program the orginal remote key of camry 2003 XLI V4!!!
I found this on the internet try it it MAY work.
Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
Perform these steps within 5 seconds
Insert the key into the ignition (don’t turn it)
Perform these steps within 40 seconds
Close, then open the drivers door.
Insert the key into the ignition (don’t turn it) and pull it out.
Insert the key into the ignition and leave in the ignition.
Close the drivers door
Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
Remove the key from the ignition.
Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Open drivers door
Toyota charges over $30 for that!!!
How to program a second master key
http://www.acdcmanuals.com
You don't program the key you program the computer, however if you have the original key you can remove the antenna out of the key and make a new key and fit the antenna into the new key, the computer uses a small transmitter to ping the key in order for it to start, there is also a wire that attach's to the key to activate the transmitter once the key is inserted. To change the transmitter signal requires special scanners and the tools to change they keys pinging antenna. This information is only given out to dealers and Lock smiths as it is part of the anti theft system, there are many different disks thatare changed to ping back the frequency to the computer, with these new keys you can create thousands of keys with a different code and a different key cut. Before the advent of computerized key there wee only 7 key cuts that changed every 7th car so basically in theory your key would fit one in seven cars in a large parking lot so it made for finding a car and stealing easy. Some of the older keys had batteries in them but they figured out when the battery went dead you had a pull toy so they changed it to just have an antenna that bounces the signal back to the computer, this is a simpler way to explain this but give you can ideal of how it works, That's why they charge $100.00 to make two new keys, you have to cut the key to fit the lock then program the computer and test it that it works. Hope this helps you.
Followed Donnie Wilson's instructions and it worked!!!
