Universal remote but cannot fine a code to program it https://electrohelponline.blogspot.ca/ http://www.remotecodelist.com/ Codes for Universal Remotes How to Program Universal Remote
If the universal remote doesn't have Vizio listed, try using the codes for Olevia. I use an Olevia remote as a second remote on my Vizio and it works fine.
If you happened to get the Phillips brand universal remote, try code 1702.
It worked on mine.
Joe
Read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
SOURCE: lost the remote code book for Rca universal remote
codes are 1054, 1133, 1155, 1161, 1162, 1166, 1176
SOURCE: Universal Remote iwave
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
