You dont need to buy anything from radio shack, the inverter that you have will be just fine. i have used smaller and im sure cheaper inverters with no problem. i keep my company laptop constantly plugged in and charging all day everyday running service calls.
I don't think that you will harm the computer. I think that you will potentially shorten the lifespan of the toshiba power supply. I would not plug the toshiba directly into the car inverter, but plug the toshiba power supply into the car inverter, let it downgrade the power going to the toshiba.It's not the 175 watts that makes me nervous, but the reqiuremnts for plus/minus 5% of the 19v 3.95 amp supply to the toshiba from the 175 watt inverter. Measure you amperage from the inverter, compare it to the 4 amp range supplied by the toshiba power supply.
