2004 Lincoln Aviator Logo
Posted on Dec 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
Anonymous
Level 2:
New Friend:
  • Expert 153 Answers
  • Posted on Dec 17, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
153
Questions
0
Helped
68897
Points
455
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
Where is the fuse for the radio 2004 Lincoln aviator?
if you have air ride turn it off it runs at anytime so if that's it you have a air ride problem....battery may not be in good shape/alternator as well can test battery and alternator free at advance auto to rule this out....g/l
How do i reset code on 2004 lincoln ls keyless entry key pad without dealer or origional code?
Can not be done, in order to do anything code is needed, as far as changing the code i think you may need to replace the module.
Lincoln has always put the code in the trunk on hinge, open the trunk and look at both hinges, there should be a small sticker with the door code. good day.
2helpful
Need factory key code for Lincoln avaitor 2003
Bad news. The keys have a computer chip which is matched to the Security box in your vehicle,. They can only be rematched at a Dealership using their machines.
You can get new, blank keys cheaper on the internet, but only a Dealer can energize it to work with your car.
WHERE CAN I FIND THE DOOR KEY CODE?
The universal lock number for ALL Lincolns, and Fords is...press 8 then 9...:) The factory 4 digit code to unlock the door pad is located in the trunk under the lid...sometimes hard to find...You can get free help with this from your local Lincoln/Ford dealer's service manager...they sometimes hace to call the Ford national contact number to secure the factory 4 digit code for your specific Lincoln. There are other uses of the key pad too. Be sure to be persistent with the dealer or national hot line...they can help:) Hope this helps.
1helpful
Check engine lights stays on with rough idle 2004 lincoln avaitor- what sensor needs to be replaced?
You will have to connect a scan tool to the vehicle to pull any codes that the computer is sending.
The number of the code will help us find the problem.
A rough idle could be a fuel or electrical problem.
Please let me know what you find.
1helpful
2answers
The pad is long with five buttons, two numbers on each button. 1-0
No idea what your question is, but if you are asking what the pad on the door is, it is a code pad to unlock the doors, open the trunk etc. I don't know if they still do it, but Lincoln use to put the base code on the trunk. Look around for a tag stuck to the trunk arm, or trunk lid. When you enter the code it unlocks the doors and if you push other #'s after the code it will open the trunk, turn on lights etc.
Hope this helps.
2004 Avaitor brake problem
right behind the rotor itself just inside are babypads and if they are loose it will make the car acts as if the emergency brakes are on so take everything off and behind the rotor you should see these little pads
2helpful
I have a 1993 town exec.how do i change the door security code
call ford with the vin they may be able to help you get the code
Top Lincoln Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
