Transferring images from a Memory Card to a Windows Computer
Follow the steps below to transfer images from a memory card to a computer running Windows.
Step one: Insert the memory card
Follow the steps below to insert the memory card into the HP All-in-One.
Turn the memory card so that the label faces left, and the contacts are facing
your HP All-in-One.
Insert the memory card into the appropriate slot on the HP All-in-One.
NOTE:
Some portable USB flash
drives with a read-only partition, such as U3 smart drives, might be
incompatible with the front mass-storage port on your HP All-in-One.
These read-only partitions are added by the drive manufacturer and may
include utilities and other software. Refer to the manufacturer for
additional details about your drive.
When the memory card is inserted correctly, the Photo light next to the memory card slots begins to blink. The message Reading...
appears on the color graphics display. The status light next to the
memory card slots blinks green when the card is being accessed.
If a memory card is inserted incorrectly,
the status light next to the memory card slots blinks amber and the
color graphics display shows an error message such as Card is in backwards
or Card is not fully inserted.
CAUTION:
Never attempt to remove a memory card while it is being
accessed. Doing so can damage files on the card. Safely remove a card
only when the status light next to the slots is not blinking.
Step two: Transfer images without using the HP Photosmart software
After inserting the memory card into the
HP All-in-One, the memory card appears as a drive on the computer.
Follow the steps below to transfer the images on the memory card to the
computer.
Press the Photo
button to display the Photo menu.
Press the down arrow button (
) to select Transfer to computer
Follow the prompts on the computer to complete the transfer of images.
NOTE:
If there are photo files
on the memory card that have never been transferred before, a dialog
box on the computer asks whether you want to save the photo files to the
computer. Click the Transfer
option and all the new photos from the memory card are saved to the
computer.By default, the image files are saved in month and year folders
depending on when the photos were taken. The folders are created under
the C:\Documents and Settings\username\My Documents\My Pictures folder.
