ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
Posted on Dec 17, 2009
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
What is the problem of this type of error Chassi Intruded" then "Fatal Error...System Halted" Chassi Intruded" then "Fatal Error...System Halted" pls send me the solution.
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Feb 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
2595
Points
10
Okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
muthushankar
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 10, 2013
muthushankar
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2146
Points
Asus p5gc mx motherboard chassis intruded problem how to read the problem
Cmos settings wrong chassis intruded fatal error system halted
Hello download the manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GD1VM/#download
Select first windows xp (i guees)
Click on manual and hit global for download.
Unzip the file before you can read it.
You also need a pdf reader to read content.
Good luck
1helpful
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Chassis intruded ! fatal error.....system halted
Some cases have a switch that activates if the case has not been closed fully.
This sounds like the type of error report this problem causes.
Make sure that your pc case is fully closed and has not been damaged
How to troubleshoot the error message of my pc? CMOS Checksum Bad Chassis Intruded! Fatal Error...System Halted.
looks like you have a bad ground connection in your motherboard, check all the connections , then restart the machine with the minimum devices conected...
thanks
2helpful
3answers
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
2answers
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
8helpful
2answers
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
1helpful
Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
