Question about Technics SL-1200MK5 Turntable
Technics SL-1200MK5 voltage or fuse problem
I bought a technics Mk5 1200 in america, they woekerd just fine, they told me that they should work in europe with 220 v but when i plug one the red light when on and the i hear a clap and then nothing dead.. i think the fuse whent off how do i replace it??? and were is this internal switch to change from 110 to 220?? thank you very much
    Scholar:
  • 85 Answers
To change it from the 110 to 220 the switch is under the turntable platter. Put your fingers in the 2 holes under the slip matts and pull up evenly. It may be a little hard but it will come off. As for the fuse...its inside the deck. Unscrew the feet and all the screws. the black rubber part will come off. Good luck!
Posted on Apr 28, 2010
6ya staff
SOURCE:
110volts plugged in to 220volts
In a normal world it will cost you your powersupply , or do younwant a 110v unit use in an earopean unit. Buy a connector which turns the 220v into 110 v and real good once aint cheap , but you need a good one, since the psu in the technics are weak
Apr 22, 2014 | Technics SL-1200MK5 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
Technics SL-1200MK5 Pitch Control Problem
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Mar 21, 2010 | Technics SL-1200MK5 Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Hi i bought my technics 1210mk5's in america and when i gor back to ireland i had them converted to 220v as this particular model is not dual voltage. The 1210's worked fine then when i used a plug pin...
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Jul 10, 2009 | Technics SL-1210MK5 Turntable
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Jun 14, 2009 | Technics SL-1200MK5 Turntable
Computer not playing my technics table
More than likely the RCA cables need to be replaced. Torque, Serato, and all digital dj programs require a clear signal path coming from the source (turntable, cdj, etc). If it does not have a clear signal, or 1 side is louder than the other, it will not work.
You have to remember, these are analog turntables connecting to a digital system. The signal quality is different, and your RCA cables have to be prestine.
The following cables work very well for this type of configuration:
MOGAMI RCA CABLES
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 18, 2009 | Technics SL-1200MK5 Turntable
Technics SL-1200MK5 Turntable Logo
724 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
