I have an Olevia 332 b11 LCD tv. I want to mount it to the wall and want to make sure I am using the right mounting points. There are only 2 small threaded holes in the upper frame that would line up with the mount arms. I do not have a plate type wall mount. Can the tv be mounted using only those 2 threaded holes? Or do I need to get another mount to use the mount in the center back of the tv? Thank you
There are the mounting holes in the middle of the tv back, but I have the mount with the 2 arms. Is there another adapter available to attach a plate to the arms and then the tv, or is it possible to use the 2 holes on the outside edge that seem to line up for the 2 arm mount. Thank you
after I take out the screws. the back panel won't come off
