You have all the resistor are correct! Yes I can Tell you exactly what you need to know and How to Save settings after you adjust convergence, I have to pull out my manual on your hand unit Be right back. first you need to go to front of TV remove front bottom panel to where you can see the front of chassis on the board you replaced ICs there is a small blue contact button with TV on press and hold for 5secs Convergence Pattern should appear! You will need your hand unit to begin to adjust convergences.
Testimonial: "Your information was helpful but did not solve all of my problem."
On your hand unit 2 & 5 move up and down 4 & 6 move forward and backward Press Select button
to adjust (Info) button for green (0) for RED (Ant) button for blue To save adjustment Press pip mode twice then shut TV off unplug wait 5 sec plug back in then turn on.
Did you not get what i posted on how to adjust 2 ,5 move up and down 4 and 6 move forward and back ward The info button is for GREEN the 0 is for RED and Ant button on hand unit is For BLUE
to save adjustment Press PIP twice then turn set off unplug wait 5 sec plug bac in turn TV on.
yours is the DP17 chassis Select is to stop at where you want to adjust and move adjust little arrows up and down back and forth on the select button
To move the lines up and down Press 2 & 5 4 and 6 back and forth Numbers 2,5,4,6, on Hand unit
Do you have a voltohm meter? Thats how you test resistors .little arrows on select should let you move from square to square
have you try magic focus to see if it will aline up Press PIP MODE and then PIP CH wait untill it goes thru complete pattern untill green dots appear turn TV off wait 5secs then turn back on see what you have then.
Where your select button around it there is an arrow pointing up and one pointing down and one to the left and one to the right use them the ones on the outer sideson select button.
BINGO toggle thats how you get it to move to square to adjust 2,5,4,6 numbers are your cursors to move up & down ect
TOGGLE should allow you to move from square to square then you Press select then use the numbers 2,5,4,6 repeat this each time you move from square to square.
Ok Press Select then 2,5 for moving up and down 4 and 6 for moving forward and backward then when you get to square that is out of line Press Select again then toggle up an down see if lines move up and down.
toggle is what lets you move the lines up and down and 2,5,4,6,lets you move from square to square you press select when you are ready to adjust, after you have made adjustment to the lines and when you are ready to move to next square Press select again.
Just wondering Have you Fixed your TV and did you firgure out How to adjust convergence?
Hey ,I just wanted to let you know just in case others Look at this reply to Make Sure they Use STK392-150s and Not the STK394-160s! Let me know how your TV turns out!
Well i tried this method for manual convergence. i got the screen to come up and i can move the curser around but i can't move any of the lines? you said push select to be able to move the lines?
Hitachi 43uwx10b. How do i test resistors for convergence? i replaced i/c chips with upgraded stk394-160 and all resistors i was told rk42=3.3ohm/ rk46=1.8ohm/ rk50=2.7ohm/ rk54=1.5ohm/ rk58=3.9ohm/ and rk62=2.2ohm but tv is still way out of convergence? Are all these resistors 1 Watt? Are these the correct values? are there more resistors i need to replace? Or can i simply try to adjust convergence manually? Original remote is CLU-5713TSI. Can you guide me through manual convergence?
No i got that post.But when i'm in the convergence adjust part all lines will switch lines but the lines won't actually move to adjust. i tried pushing select on a line then use numbers to adjust but it doesn't it just moves the line to the next spot? tryed using the select knob to move the lines into adjustment but it does nothing. Does this mean i still have a convergence issue? how do i test resistors?
I tried that nothing would move?
I appreciate your help i understand how its suppose to work but it's still not working. None of the lines will adjust. Any other suggestions? I'm thinking i still have a bad resistor or something. How can i test the resistors and ic chips?
I'll have to buy a voltohm meter. the select doesn't do anything, i don't get any little arrows:( Just the grid and i can move the curser location but i can't move the lines. Select button does nothing.
Ya tried it. it does nothing. Now when i try to use magic focus it doesn't scroll though like it used to just has a convergence screen with 9 plus signs but i can't adjust them either. i can scroll from one to the next but can't adjust.
My select button is a toggle button. there are no buttons beside it exept volume up and down and channel up and down. my select button is a toggle that moves up down left right in a complete circle and pushes down to select. i've tried everything i can think of to no avail which leads me to think there's still something wrong on the circuit board.
2,5,4,6 actually moves from square to square. when i'm on one i want to adjust i try pushing select then a direction on the toggle but it doesn't move. then i tried pushing select and using the 2,5,4,6 but it just moves to the next square. Doesn't adjust.
