We have a verticle opening of 29.5" for the Bravia KDL46V3000 which is 28.75". Is there a low profile stand for this TV that will allow it to fit into the space? thank you
it is not necessarily my first option - I want to try to avoid cutting a hole in the expensive piece of furniture (wood back of the wall unit) or having to affix an additional panel to the interior to install the mounting hardware to. If there is a universal stand that would work, I would rather do that - a much easier fix for the client to deal with. thanks for your helpit is not necessarily my first option - I want to try to avoid cutting a hole in the expensive piece of furniture (wood back of the wall unit) or having to affix an additional panel to the interior to install the mounting hardware to. If there is a universal stand that would work, I would rather do that - a much easier fix for the client to deal with.
You can't post conmments that contain an email address.
take the tv to a repair shop, a verticle problem is not a major one. verticle has a ic, a output capacitor electrolitic which can dry up, and a scan coil on the tube. on the scan coil we have 4 wires two wires go to a line trasfirmer for horizontal, and two to an ic via a capacitor and ground.
ask the tech check what i have told you.
okay
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Put some ice on the bag put it in the stand for a few hours,take the hair dryer max setting put some heat on the plastic,might loosen the moistster,and heat compound in there.Will able to lift.
