Printer light blinking, does not accept print command and the message on the Screen reads: The following print cartridges has a problem:
Cartridge on Right
Tri-color
I saw the blinking power light issue yesterday with the cartridge error for the black HP 21.
The error was due to the HP21 being empty
I refilled the cartridge and press the power button and it cleared the error and now it prints fine on my computer..
I want the printer drivers HP deskjet D2360
Cartridges have small electrical contacts. It sounds as though either the cartridge is faulty or it may have got stuck in the wrong place.
Firstly turn off the printer.
If you are using it with a computer via a usb connector, disconnect the lead from the printer.
Disconnect the power lead from the printer.
Lift the lid to gain access to the cartridges.
Ensure they move freely along the track from right to left.
Remove the cartridges and re-insert them one at a time.
Close the lid, reconnect the power lead and USB connector.
Switch the printer back on.
If you are using it with a PC, your computer should automatically detect it after a few seconds. If it doesn't then restart your PC.
If this does not clear the problem, try new cartridges. If it still does not work, the printer may have a control fault.
Hope it works, good luck!
the light was still blinking even after i refilled the ink...
i want the hp deskjet d2360 drivers for free pleas tellme the web pages
