You need to check and make sure that you are trying to view the PS3's output on the proper channel or input on your TV. If you need to scroll through every channel and input.
If that doesn't work try replacing the A/V or HDMI cables. If it still doesn't work you may need to send it to Sony and have it replaced. The video output section of the console may be bad or not functioning correctly.
If you have a friend with a PS3 try to see if they will bring their's over and let you test it out. If their PS3 won't display then it's something wrong with the wires or the TV.
You need to make sure you have the correct Display setting for the connection you have. HDMI output will need HDMI cable to TV. Composite or component will need those cables. I had this problem (Selected Componet output when I had HDMI cables hooked up. I was not able to see the display. I had to hookup componet cables to see the menu and then change display to HDMI.
