Dell Dimension 8300 PC Desktop Logo
Anonymous Posted on Dec 16, 2009
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a green light lite and the codes 1234 have no power either. I am totally lost and frustrated and I want to throw this computer over the cliff and or give it a Viking Funeral. LOL. HELP!!!!
  • 6 more comments
  • Anonymous Dec 16, 2009
    Its on my Dell Dimension 8300 computer.
    Diagnostics codes are blank. My computer is a Dell Dimension 8300.
    How do you flash the BIOS?
    Can I reset the BIOS? Jumpers settings
    I will get the powersupply tested tomorrow and I will tell you if its defective or not. Thanks for your help.
    dell dimension 8300 soild amber light. This is crazy! I unplugged the harddrve and the cd rom and now the fan comes on and the motherboard has a green light. Do I have a Defective Powersupply thats not getting enough juice?
  • Anonymous Dec 17, 2009
    thanks Dageezer! you were right too. The powersupply. one of the wires were fried. Getting a replacement today.
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Dec 16, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405364
Points
12062
The flashing amber power led is an indication of a power supply failure. One of the rails, 12v, 5v, 3.3v etc has failed.
Replace the power supply with any 300w + standard ATX power supply to resolve.
Anonymous
Level 3:
  • Master 2,567 Answers
Anonymous
Master
Level 3:
Answers
2567
Questions
0
Helped
671528
Points
7153
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Testimonial: "The powersupply was faulty! Man....I didnt look at the wires until now. Thanks alot! Excellent Service!"
Melissa Yourich
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 28, 2013
Melissa Yourich
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1805
Points
Power Supply is bad. It seems snappier now.
Yellow light on the power button of my Dell Optiplex GX520. I've tried: 1. Replaceing the power supply 2. Replacing the CMOS battery 3. Removing and reinstalling the RAM memory. 4. Replacing the...
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
2answers
Solid orange light on my vostro 200
If your fans come on full blast then you have a bad motherboard. If the amber light blinks, you have a bad power supply.
2answers
I have a amber light on the front of my Dell 1625 Help what is it?
1. remove all external peripherals (usb, internet, ext mouse and keyboard)
2. remove the battery
3. connect ac adapter alone and check if still the same
4. reseat the memory and check if still the same
5helpful
3answers
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
5helpful
2answers
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
2answers
HP Laptop(Compaq nx6310) Lights are blinking
You did not specify if you are talking about the lights below the screen or the ones at the front of the palm rest.
Have a look at pages 1-2 to 1-5 in the HP support manual (link).
The description might help you.
It seems to me that you are talking about the battery light (which is amber when the battery is charging) and the light for the drive (which is blinking when the hard drive or optical (CD/DVD) drive is in use.)
Just as a side note: if your hard drive light is constantly blinking, although the CD/DVD drive is empty AND you are not saving or accessing data - this could be a caused by not having enough RAM installed. In this case, the excessive memory has to be written to your hard drive, which could result in excessive blinking of that light.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
