"Sharp ar m455n error code 3A L4 30"
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
I have error code l4 - 30
AR-M455 error code L4-03 most common problems:
1. DV mag roller seized
2. Drum blade flipped
3. Spring behind coupler that turns dv unit has been up-dated (stronger), stretch spring for field repair.
4. Fuser locked-up: bad bearings, debris binding up fuser.
I have Sharp AR_M351 & need Repair booklet please help me tank you.
