We have a Krups KM7005 coffee maker/grinder . The problem we have is as follows = The grinder works fine and all lights come on as if it were operating properly , however the heating pad doesn’t get hot and the water doesn’t drip at all . Is there a fuse that needs to be replaced or smething ?
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
This coffe maker has a heating pad/hotwater heater. The water flows through the heating pad to brew and they fail frequently. Krups replaced my whole unit.
