Canon MX700 Office All-In-One InkJet Printer Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
U052 prnt head is incorrect install the correct print head...it is the correct head head made by Canon how can I get rid of this message and resume printing..
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Dec 16, 2009
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130343
Points
8732
You can check that it's installed properly, after that all you can do is replace the printhead. They are like a light bulb and burn out when you least expect it. If you printer is less than a year old Canon will replace the printhead, after a year you have to buy a new one. Anywhere from $60.00 to $100.00 The part number is on the side of the printhead, the number starts with QY6, the numbers after that are the actual part number.
Why my printer mp610 shows code U052, what does it mean?
The U052 printer Error occurs in two different scenarios. The First one is when the print head is not installed properly on the canon printer. And the second Scenario is When the print head is installed well but is not working properly.
Follow the steps to fix the U052 printer error code. Need any type of help contact printer experts through Free Live chat.
5answers
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
2answers
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
25helpful
4answers
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
20helpful
2answers
Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
22helpful
2answers
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Code U052
It's most likely an after market cartridge. Try a diiferent one or get the OEM.
old marine
old marine
ZJ Limited
ZJ Limited
