SOURCE: How to set the time on Acu-Rite model 13100 clock?
Go to:http://www.atomixtime.com/pgs/pdfs/13003%20THOR%20INSTRUCS.pdf
and print it out.
SOURCE: I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
SOURCE: My Acu Rite 00992 weather station switched from F
Press Set-up, third round button from right and hold it down until "hour" on the time display flashes. Then press "set-up" again, and again (for me it was 8 times), until you get to where the "C" is flashing you want to change to "F." Now, press "Min" on the far left once to change it to "F." Press "set-up" two more times to get out of the cycle, and you're done.
SOURCE: Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
