Hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Testimonial: "Any insight to a problem is a positive step."
When the speed control knob is turned to high speed the power on light flashes and scoter won't move turn back till ligh stops then goes but slower
With the speed knob turned to high speed it switches of the power light if you turn it counter clock wise slowly then at 3/4 travel it brings the power light back on scoter moves but much slower than usual is it the speed control pot that is at fault
I have as similiar problem with my Pride Legend XL. Even
with the speed pot turned down on low speed, it flashes continuously.
Problem with no-go (flashing LED but no discernible flash code)after key on
