hello;)
ok! put a empty cd in the cd reader
restart the computer and wait.
if it's not working you need a local expert intervention
good luck
You need to replace the optical drive. Go to web site of Other World Computing and order a CD/DVD super drive which will burn/play discs and even burn on dual layer discs. Cost about $80 US plus your free labor to install the thing.
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
8065 refers to a cross-platform error (like between a p/c system and a mac system). You could try copying your file to a cd and burn the cd to be compatible with pc or mac and then transfer to the other system.
You cannot write onto a dvd-rw that has been formatted for Windows using a Mac Superdrive. Most likely, when you put the dvd-rw into a Windows machine w/Visa, you erased it, but actually it formatted the disc for Fat32 or other Windows format. Mac's are often brand-sensitive often when it comes to DVD. I've had luck with Memorex and HP, or Apple has their own which will work (from an Apple Store or Best Buy.)
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
I would suspect a corrupted catalog file, these are the map that a comupter uses to find its way around the drive, they are also the first casualty when a crash corrupts something. Disc warrior will write a new catalog and fix everything. PCs do not see discs formatted for macs.
