Ovens Logo
Posted on Dec 15, 2009
I hava Whirlpool Accubake oven model RBS245.
I have a Whirlpool Accubake oven model RBS245. Neither the broiler or the oven elements work. I can set the timer and temp but the oven never heats up. Can some one please help me with this problem? Thanks.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 13, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1437
Points
DISPLAY READS E1 F5
When baking in whirlpool accubake electric stove model GR475LXMS only the broiler works not bottom element what could be wrong?
The element could be open or the thermostat for the oven could be stopping power from reaching the element
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
I have an whirlpool built in electric oven, model RBS245 that we just changed the control board. now when we turn breaker back on we get the code E1 & F2. can you tell me what these codes mean
I have an whirlpool built in electric oven, model RBS245 that the electronic panel doesn't light up, but makes the tones when pressed
ANY SUGGESTIONS?
Broiler element and oven element not working. oven has power to it, all lights and displays are working,
Since neither the broiler or bake elements are working I would suspect either the sensor - sensing a higher temperature than set meaning the sensor is defective (Item #29 on the diagram) - http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Wall-oven-Parts/Model-YRBS305PDB5/1198/0125300/W0703198/00001?blt=06&prst=&shdMod=
You might try the self clean function and see if the elements get hot. If they do then it is most likely the sensor.
Hopefully, that will fix your problem, but if not then it could be in the microcomputer which is a problem because it is a part that is hard to find.
1helpful
2answers
Wirlpool gold accubake system is not working properly. Broiler works but oven does not heat up properly
If your broiler is working but not the oven, you just need a new bake element. This is a very simply part to replace. Just give us a call or email us with your model number and we;ll send the correct part out to you right away. 972-859-0929. We'll ship this to you and you'll be cooking in no time! We look forward to working with you and hope to hear from you soon. :>)
Oct 03, 2009 • Ovens
6helpful
2answers
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 • Ovens
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
