My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do
not need a diagram you need to go purchase the wiring harness for your
make and model and year car. Match the colored wires together to the
ones on the back of the head unit then connect them, then that harness
plugs into your stock car harness that your stock radio unplugged from.
You also probly need an antenna adapter cable that just connects to
your stock antenna cable to add length and then plugs into your
aftermarket radio. If you need a wiring diagram because you are trying
to open you radio and fix it because it is broke or something...good
luck to ya. Hope I helped... :)
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
