ASUS P5VD2-X Motherboard Logo
Anonymous Posted on Dec 14, 2009
Can install windos 7 in my pc. my pc is "asus p5vd2-x, 1 GB ram, 512 grafic card and 3 GHZ proccesor.
Anonymous
Level 3:
  • Master 2,567 Answers
  • Posted on Dec 15, 2009
Anonymous
Master
Level 3:
Answers
2567
Questions
0
Helped
671177
Points
7153
I believe your computer specification meets the minimum requirements for Windows 7. However, for better performance, it is recommended that you have 2 GB of RAM.
Testimonial: "thank you dude :) but I have 1GB ram and I just installed wind 7 32 bit. and supports very well. :) "
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
2answers
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Hi, I use asus Pro T5750 series with processor Intel core 2 duo 2.0 GHz with windows 7 ultimate OS 32 I have installed 2 x 2 GB RAM but see, Installed 4 GB (3GB usable) In Bios I see 4096 MB. How I can...
Hi Trifon,
you are detecting a known problem for 32 bit operating systems.
The problem for those system is that they can manage maximum 3 Gb of RAM.
If you want all of your RAM used you have to install a 64 bit operating system. Windows 7 has also a version for 64 bit as well as windows xp (but is not good supported) and windows vista.
Big city rigs
first check if your computer answers the following requirements:
Windows® XP/Vista
Minimum Requirements:
  • Pentium® 1.7 GHz or similar processor
  • 512 MB RAM
  • DirectX® Compatible Video Card
  • 128 MB Video RAM
  • DirectX® 9.0c
  • 2 GB Hard Drive Space
  • Mouse
Recommended Requirements:
  • Pentium® IV 2 GHz or similar processor
  • 512 MB RAM
  • 3D Video Card with at least 256 MB Video RAM
  • DirectX® 9.0c
  • Mouse
if you do, please tell me exactly what happens when you try to install the game
3answers
Compatible with windows 7
yes its compatible with windows 7.
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a...
request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
5helpful
2answers
SLow running of Crazy Taxi 3 on PC
friend.
you should have ram with up to 2 gb .
although your processor is good but u need more video memory.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
