You need to set
wan type to PPPOE for ADSL
ADSL has one IP address coming out of your building to the ISP
How does it connect many internal computers to just one outgoing IP address you may wonder. It uses different port numbers for each computer on the same ip address via a PPPoe connection .
http://searchnetworking.techtarget.com/definition/PPPoE
if still stuck call your isp for help
you will most likely need dynamic IP for the isp ip and DNS /
SOURCE: Port Forwarding
hello just got sorted, hope this is helpful ,,,i logged onto port forwarding.com and a long story short , basically had to interigate my zyxel router, what you do is fix the ip add of your wireless connection (the computer) to a manual fix eg. mine is now fixed to 192.168.1.40 with a port tunnel 46207(utorrent preferences)i picked this out of my head as there is a scale from one no. to another. you then get the password to your router and get into its internal settings via password and go to the port forwarding section, you then tell the router that the computer has a fixed ip add (the one above ) and dedicate a fixed port or tunnell/window mine is 46207save this setting on your router and your home and dry, basically your telling the router that the computer has a fixed add, with port window??? and off it goes ,,,,portfward.com tells al
SOURCE: After configuring network TCP/IP
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
SOURCE: can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
SOURCE: I have an EQ 660R ADSL router supplied by embarq
i have the same problem trying to connect throw usb
