I paid $75 for this TV because it had a cracked screen (lower right corner) and the screen was bright fuzzy orange. Anyways, after I opened the case and cleaned the screen and bulbs, removed spider webs, etc, the picture is amazing!!!! I looked at the post "cracked screen" but I could not find any parts for a replacement screen. Would it be worth it to replace the screen with a custom cut piece of plexiglass?? It really doesn't affect the picture but the TV is in great condition otherwise and it would look "like new" with a crackless screen cover. Thanks for reading!!!
Seth
How much does a screen cost does anyone know
How do you remove the frame on a RCA projection screen to get to the lenticular screen?
You will need a lenticular screen also . st plexiglas wont work. The lenticular screen has ridges and kind of opaque in color the outer screen could be plexiglass if need be, But you definitely need the lenticular screen.
oh okay, the lenticular screen is perfect. It's the outer screen that has a crack in it. I was tempted to remove it but I think I'll try the plexiglass unless you know where to find a cheap replacement.
DID YOU USE PLEXIGLASS AND HOW DID IT WORK IF YOU DID I HAVE THE SAME PROBLEM ALL I DID WAS TAKE THE PEIECE THAT WAS CRACKED AND PUT IT BACK TOGETHER BUT I WOULD LIKE TO REPLACE IT SO IT IS ALL ORIGIONAL SO DID YOU FIND A REPLACEMENT
My Lenticular Screen is broken and my outer plexiglass is broken too. Where can i buy replacements? Help me please!
I have a 42" Toshiba, but since it is about 8 years old, they have discontinued providing parts. The very front plexiglass thin screen broke but everything else is fine. Do you have any suggestions?
I have a 52 in. RCA and there is a big crack in the centre and was wondering how much to fix and can i do it myself
me venderias tu pantalla es mi correo [email protected] y mi cel es 0445511713401 me llamo ivan tengo una pantalla igual nueva pero de quemo una tableta
