Dell Latitude D600 Notebook Logo
lee Posted on Dec 14, 2009
Device manager problems
Had to get my hardrive wiped so that i could reinstall xp due to a virus but now in device manager theres afew exclamation marks in yellow up in other devices. network controller, pci modem and video controller (vga compat)
what do i need to do to fix these problems? thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Dec 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
2829
Points
44
Go to there web site and search for the drivers. ones you enter their web site on the colum of search type in the model of your dell laptop with the request for the drivers on it and press enter.
My hard disk hardrive dont read on my computer
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
2answers
2helpful
2answers
This hardrive was in a working unit (WD 800AAJS Sata) And now I get the message no boot device found I have used a new cable and power supply and tested on a Dvd rom, so the connections are...
If you are trying to use the drive in a windows XP system you will need a driver due to the fact its a SATA drive (very few are supported by Win XP) .
You should be able to find a Windows XP driver on the Western Digital website.
At the start of the Windows XP install process you will be asked to press F6 to load SATA drivers.
If my memory serves me right you will need to have the driver on a floppy disk to install them.
This should sort your problem.
4helpful
2answers
No sound after reinstaling Win XP
go to HP.com and download the sound drivers
install and restart the comp
2answers
Wireless adaptor not installing after i wiped my hard drive
ok delete all the adapters in device manager and then uninstall your wireless adapter(after turning off the computer) turn the computer back on with adapter still uninstalled shut down the computer again and reinstall your wireless adapter start computer and it should find the wireless then if need be install drivers again
No wifi after re-load of xp system software
Did you reinstall the drivers for the device? Check the Device Manager for your system and see if Windows sees the wireless device. If you have a red X, the device is disabled; if you have either an unknown device or the wireless device with a yellow dot with a black exclamation point, then either the driver is not installed, or the driver is improperly installed.
CD rom drive not showing up in
Common problem. CD driver did not install correctly.
Go to Device Manager. Unistall the CD drive. Reboot.
The Operating System will then rescan, locate the drive, and reinstall the driver.
Good luck.
3answers
When the computer starts up. "Gateway" appears on the screen. Then the computer freezes. None of the reinstallation discs do anything. How do I fix this?
Reboot and keep tapping on F8 to go to Safe Mode. Do not put the reinstallation disk yet. Once in Safe Mode select "last known good configuration".
You can also run "Chkdsk" from the C hard drive Properties if you get to Safe Mode. Double click "My Computer", right click on C drive, select Properties, select Tools tab, go to Error checking and click on "Check now" then check "automatically fix file system errors" and "scan for and attemp recovery for bad sectors" and click "start"
If that doesn't work proceed to do System Restore in Safe Mode or remove previous programs that may have caused your Windows to freeze. If you suspect virus, run your anti-virus in Safe Mode.
If none of the above works then try your XP CD (or reinstallation disk) and do a repair.
Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
