NAD T762 Receiver Logo
Posted on Jan 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delayed Sound from Center Speaker
With "A" Speakers ON and "B" Speakers OFF, there is no sound from center speaker and muffled sound from side and rear speakers. Remains this way from a cold start for about 25 minutes then all is normal.
To obtain normal sound sooner, it is possible by continually pressing "Surround Mode" Button until start to hear sound breaking into center speaker and turning up the volume (this can take several minutes).
Have checked all speaker connections and replacement of Center Speaker but problem remains and exisits every time the 762 is turned on.
  • aubrey0 Jan 21, 2008
    Thanks for your reply.
    It does not matter what I put to 761 input, 2 different satellite receivers, dvd player, etc. has same problem. Have checked settings.
  • aubrey0 Jan 23, 2008
    Reference Solution #2...Please provide link to Website,
    Thanks
Anonymous
Level 2:
Scholar:
  • Expert 54 Answers
  • Posted on Jan 21, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
54
Questions
Helped
37595
Points
100
Is this when your playing a DVD ? or for the stereo ? or normal cd ? if playing a dvd you should select the Dolby Pro logic Button/ option , for radio put it on Stereo sound or Virtual Surround, and for cd,s the same, check your dvd player settings in the audio option on the tv screen , and make sure it is set to dolby pro logic ,,
Anonymous
Level 2:
Scholar:
  • Expert 128 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
128
Questions
Helped
147938
Points
259
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
  • Anonymous Jan 23, 2008
    what happened to my link?
    sorry, idk what hapened to it
1helpful
IM67 sound system
The center speaker 900 watts, the two speakers on sides 300 watts each and the subwoffer 500 watts. Total of the speakers power 2000 watts.
4answers
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
No dialogue on SONY home theatre system when connected to SONY TV
I had a similar problem with my Philips home theater.
What I did was to go through the set-up again with the manual in hand and I got the speakers working but I sill have problems with radio the sations.
Kolbrun
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
2answers
No human sounds when playing dvds.
sound like the center channel is out
either bad connection at speaker or receiver is not putting out sound on center. A quick swap of speakers at receiver end will tell you if it is the latter
Bose 901 Series IV BLOWN?
Yes, if you hear any sort of crackling sound, that means it has blown. Given the cost of these units, I would suggest repair. I would also suggest contacting Bose, as many of their products have a lifetime warranty, so you might be in luck. Although, blowing your speakers because you made your speakers go louder than they were supposed to, is no covered in the warranty.
You can approach the repair in 2 ways..
1) Send in to Bose for repair - suggested
2) Take it to a service center, and see if they will be able to recone the speakers or replace. Most service centers are familiar with the 901 series, so you should be ok. If they have no idea what your talking about, stay away.
But yes, they are worth fixing.
- OPTiC
DJ & Pro Audio Repair
1helpful
Call 1-8O5-465-751O Number To Fix
Yes, you can connect all the other speakers and not have a center speaker. It will not damage the amplifier. But be aware, that many of the surround functions will not sound good without the center speaker. In just about every surround mode the center speaker gets more audio to it than any other speaker. It would sound better if you took one of the rear speakers and used it for a center speaker and have one rear speaker output no connected. The rear speakers get the least amount of sound going to them in all surround modes.
I hope this helps and a Fixya! rating would be appreciated. After all, it is the only reward we get for offering people like yourself free help. Most people never even bother to rate our free help here.
Thanks,
Dave
1helpful
My tv speakers are muffled
The speakers sound all good because you said "the speakers" are muffled .....it sounds like a problem on the board.....a capacitor a resister but its fixable....unfortunately only by a repairman
2answers
Rear Speaker problems
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
