It hasn't been 'unplugged' until you have let it stay that way overnight. There are components that need to discharge and that can take hours.
You wrote 'standard sounds;' did this mean audio or something else?
If you have normal audio but no identifiable video, then the backlight or the inverter for the backlight has failed.
If audio is present, try looking at the screen from several angels to see if you can identify some ghost-like video.
If so, then the above suspicion is pretty much confirmed.
I hate that the modern sets seem so prone to failure, it isn't a good trade-off for the increase in quality of the results.
Most of these are not poor engineering but the effort to build them with the cheapest possible parts inside, often only saving a few dollars, but ruining their reputation.
my tla-04641c stoped taking commands the day after using it with my laptop and was stuck on so i unplugged it and now it wont turn on when i plug it in the red light comes on and i hear the relay click button nothing happens when i push the on button. any suggestions? i pulled the power board and nothing "looked blown"
Please follow the steps below to program your remote control to equipment other then your DISH receiver: Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control. 1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. 2. Press the numbers 5-0-0 on the remote control. 3. Press the Pound (#) button on the remote. 4. Press and hold the correct Mode button until all mode button backlights illuminate, then release. 5. Press and release the Power button on the remote control. 6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. 7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. 8. To verify the code works try several different functions for that equipment.Let me know if this helps and please rate the solution. lone99star
