Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
I NEED TO KNOW THE WIRING CONFIGURATION ON THE HARNESS.
