Question about Craftsman 1/2" Impact Wrench
Where do i get a replacement trigger, mine is
Where do i get a replacement trigger for my craftsman 1/2 impact wrench, mine is broken
  • 74 Answers
If your local Sears store can't help you, try looking to see if you have a Snap-On, Corn-well, or Matco tool distributor in your area. Many air tools are manufactured by companies who make tools for different distributors. I work in a shop, and have found that many of the tool trucks have parts that'll work on other brands of tools besides their own.
Posted on Dec 13, 2009
6ya staff
SOURCE:
CP 734 Trigger Broken
If you are still looking for this part I would call power tool repair at 330-630-0022 and order that part number. From the breakdown it seems you have the correct part number
Jul 24, 2012 | Chicago Pneumatic 1/2" Air Impact Wrench
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Have a Ingersoll Rand 2135 ti impact wrench with a trigger that sticks in. Don"t know if it needs a spring in the trigger part or if there is another problem. Took it apart and cleaned it and oiled...
i have the same problem, and a fellow co-worker of mine told me about the problem. here it is.. on the handle there are two slots on either side, push them in and the air inlet assembly should pop out along with a broken tiny metal rod.. this rod connects to the inlet valve and turns on and off ur impact wrench.. i have been looking for replacement parts but cant find any.. hope this helps you and maybe help me too..
Nov 12, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Impact wrench is not working at all.the air is coming out of the hole at the bottom of wrench next to where the air hose is hooked up.
fill down the air pipe wit penatrating oil hold trigger and keep movin forward and reverse wen in frees up fill wit airtool oil
Aug 10, 2010 | Craftsman 1/2" Impact Wrench
Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Apr 29, 2010 | Craftsman 1/2" Impact Wrench
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
I need to replace the chuck on a 1/2 Craftsman impact wrench.
Well, for sure you can get a replacement chuck from the hardware store or from the Craftsman dealer.
Oct 04, 2009 | Craftsman 1/2" Impact Wrench
I DESPERATLY NEED A DIAGRAM OR EXPLODED VIEW OF THE TRIGGER MECHANISM OF THE IMPACT WRENCH AS SOMETHING IS MISSING IN MINE. IT HAS NO TRIGGER CONTROL AN RUNS CONTINUOUSLY IN BOTH DIRECTIONS.
take it to a servce centre for air tools ,there is a little neoprene or plasic o ring right up in trigger area ,that gets brittle and starts to break up. bugger of a job, why waste aday they wll do it in a flash (sort of) youdoit
Aug 04, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Craftsman 1/2" Impact Wrench Logo
277 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
