Uniden Cordless Phone Logo
Posted on Jan 21, 2008
Uniden black 900 mhz basic model
I had static electricity on me, touched the phone, felt a big shock, and went to turn on my phone, and volume now is soooooooo low! It's all the way turned up, battery charged good. Do you know what happened, is it fixable?
Distressed,
[email protected]
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Feb 11, 2008
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
15535
Points
59
Julie: If you have increased the volume control to the maximum volume position ( the up touch key) and the volume is still low you have probably done some damage to the amplifier circuit with-in the set and it can't be repaired. Thank You. Jerry
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
I need a manual for a uniden 900 mhz cordless phone
Sorry, you didn't give the model #. Try going herehttp://www.uniden.com/index/manuals_results.cfm?cat=1
they might have it
1helpful
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
2answers
TV won't turn on.
Stevenson
the fact that you got shock is because something is not right inside the tv. You need to have that tv check because a manufacturer will not fabricated a tv that can electrocute anyone, specially when you turn the volume. Static electricity is always present in front of any tv that might be the cause of why you got shock. By removing your coat, and touch some metallic object you may get electrocuted, because of static electricity. Please, I want you to have that tv check, I can check that tv for you. I felt something is wrong inside the tv, and something is loose inside like pennies and toys objects. That's my impression. My e-mail address [email protected]
1helpful
Static electricity
I had the same problem when I answered my cordless phone static charge went thru me and into my phone and I had now display, so i changed the batteries in the handset and it worked. So I hope this works for you.
2helpful
Change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
1helpful
2answers
Lost manual
teddybear2me, here is a link to your manual:
http://www.uniden.com/pdf/DXI5586-2om.pdf
bratkowski and cdaniels, I need to know the model numbers before I can find you a manual.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
