Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Google on the net for error beeps
One Long Beep, Two Short Beeps
Video Problem
No Beeps
Short, No power, Bad CPU/MB, Loose
Peripherals
One Beep
Everything is normal and Computer POSTed
fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
