The inserted video have no details about the brand name of the TV. Anyway, understand that these blinking are fault indications. Count the number of blinks occur at one time switch on. If you wish to get more details about the blinking codes, check this link. Form the number of blinks, you can get an idea about which section circuit is faulty, and will make troubleshooting more narrower. Check the above linked site patiently. Blinking codes and troubleshooting procedure to many brand TVs are given.
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem. You question shows standby light stays On that means TV does not receive power on command from remote. If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution. Thanks.
TV got internal problem and goes to standby due to protection circuit activation. In protection status, standby light would start blinking in sequence with 3 seconds pause. Let me know how many times standby light blinks to find out possible problem section in your Sony KV-32FS420 TV to suggest any solution. Thanks.
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
