For some reason my computer will not load the Acrobat file of the manual, i suggest you download it and have a good look through it, or contact Frigidaire
Consumer Contact Center:
U.S.A. 1 (800) 374-4432 Monday - Friday 9:00 am - 5:30 pm EST
Canada 1 (800) 265-8352 Monday - Friday 8:00 am - 5:00 pm ESTFor some reason my computer will not load the Acrobat file of the manual, i suggest you download it and have a good look through it, or contact Frigidaire
Consumer Contact Center: U.S.A. 1 (800) 374-4432 Monday - Friday 9:00 am - 5:30 pm EST
Ok, all I found right now is; to press STOP/CLEAR when the F20 appears and then reprogram it.
If that does not solve it it says to record the error code [F20] and contact the dealer which I would recommend doing.Ok, all I found right now is; to press STOP/CLEAR when the F20 appears and then reprogram it.
You can't post conmments that contain an email address.
www.shopyourway.com > Manage My Life > Questions Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
If you replaced an element, you may have made an error in replacing it. Here is a post: (on a service call i ran across this same range with the same problem and remembering from a s/c about a year ago i had purchased the (316441801) dual element switch .. It wasn't in a box but looked the same . so i installed the switch .. and to my surprise f20 popped up as soon as I turned on the oven . This code also appeared when i removed and isolated the wire's ( i.e. no switch at all ) I spent the next 30 minutes checking wiring , so here's the reason this happens . It is a communication error code . One of the Dual elements has a (316441801) and the other has (316441804) switch . The last number is different . I found that one switch acts as a ground and the other as a positive. I'm not quite sure as to why its attached to the EOC . So when changing out one of the dual switches look at the sticker on the switch as it has the part number on it . Hope this helps and saves someone from buying the EOC as that is most likely not the problem
Depending on what motor you have in your vehicle the labor ranges from 1 hr.to 1.5 hrs.Depending on the labor rate at the shop you went to just add this to the $50.They also might have rounded it out to 2 hrs.The 4 cylinder is the one that takes the most time.I don`t know what the labor rate is there but here it ranges from about $50 to $100 dollars an hour.Hope this helps.Good luck.
Check oven sensor-- 10-11K ohms at room temp. Check wiring to sensor.
If ok - replace electronic control.
Affordable Appliance Repair
Orange County, CA
sounds like a bad fill valve...contact HHGregg. This is a warranty issue. Do not attempt to make any repairs, it would void your warranty and then you would have to bear the repair costs.
Allowing it to dry with warm air and power off should fix it You can get an dust off can from photo store and blow some of the water out to speed things up could take 24-36 hrs depending on tempature.
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction. The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example 350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model?
Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
f20 error keeps showing
