Hotpoint VTD00 Tumble dryer. Motor runs ok without belt. Motor bearings run easy and smooth. Drum turns by hand fairly easy, same as it always has done. New drum seal and rear bearing fitted 6 months ago. When belt is fitted and start switch is depressed there is a buzzing noise but motor does not turn. With top cover off and drum is helped to turn by hand when buzzing, motor will run and continue to turn drum until drum stops to reverse when buzzing starts again and motor will not turn the drum again, as if motor has too little torque.
hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Tumble Dryer Belts Archives How to Repair Home Appliances
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
You will find a groove towards the middle of the drum. This is the path the belt will run on.Just put the belt around the drum and then around the pulley of the motor. You may find on your model a spring loaded tensioner that you can move with your fingers. This will allow you to put it on without loosening the motor from its frame.They are pretty easy to put on. You may want to remove the top of the dryer if you are having trouble working with the belt. There is not much clearance in there. Total time needed with taking the top off is about 30 minutes. Let me know if you have any problems.
Sounds like the motor is turning but the belt is not so, the belt is just setting there burning. You should be able to turn the drum by hand, check the drum rollers and the belt tension roller.
