Troubleshooting Tips
1. If your HDTV or TV has multiple inputs, make sure you choose the right input your DVD player is connected to, such as Video, HDMI 1, HDMI 2, HDMI 3, Component, etc. Change the INPUT or source the HDTV is set to by pressing the INPUT button on the TV or its original remote. When you try different inputs, let the DVD player play a disc and output a constant signal.
2. If your TV has the correct INPUT or Source, unplug the cable and plug it back, or try another cable or port. Sometimes cable can short-out. Be sure they are connected securely.
3. Test if your DVD player works on other TVs. It could be your DVD player breakdown that leads to No Signal on your HDTV.
4. Try connecting your DVD player to another HDTV if your DVD player works correctly.
5. Check if your DVD player is compatible with your HDTV.
6. If the TV does nt work try to upgrade your DVD.
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are : 1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player. Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC. 2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you. Have a nice day! Good luck and take care!
The new recorder comes with security systems in it - when it encounters programs that have a "Do not Copy" signal on them it will refuse to work. This is how it's designed to work, there's nothing you can do to change that. BTW , even if you could do that it would have been illegal - recording a copy-protected program is considered by the lawyers of the channel in question as piracy .
The older one didn't do that because it didn't had the security system.
check the input selection on menu of tv, it may be trying to read dvd player without dvd inserted or another device connected to tv. also check to make sure cables are secure,. Most likely it is on wrong input.
