look in the sticker of product /model/ maker. then go to the website and search for the driver. download it. when installing the driver it will ask to plug in the printer wire usb cable from printer into computer to complete process.. sometimes the manual of printer show a procedure of menu keys to set up printer to pc to calibrate printer. .
in control panel. search for devices and printers. look for the printer when located. try a print out.give it a test. good luck
First connect your printer to computer then your printer is found as new hardware then click on no at this time then select install driver manually then next then click on show all devices then browse and locate your driver folder.then next.
Also you can update driver in devicemanager for that right click on my computer then click on property then hardware ->device manager
then select your unknow device printer and right click on it then updste driver then browse abd lacate your driver folder.
Go to Dell Journal ID: 08086MJJNF
Article ID: 316455
Date Published 1/4/2008
Last Revised: 3/25/2008
Go to www.dell.com and top right type in 926 printer; it will bring you to the next page, click on the first result: Install Dell 926 All-In-One Priter Drivers. This should help you. Follow all the directions exactly!
***Did you uninstall the first 926 driver before you did anything else. You must uninstall the first driver and install the driver for the second 926 printer.******
