The bushing on the door has all but disappered. Can these be replace easily? Also if so can you advise.
Thank you
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
I have the same ovens and you only get the bushings ac far as i know when you buy the door spring assembly .make sure you get the right one because there are 2 sizes ,the older ovens have a thicker bushing.and its not that hard to replace if you can take it apart.that door is very heavy so be careful
the flame came out from the burner is so yellow, is that normal?
is that unit made by Blogett?? do oy uhave a model3??
