Hi my samsung u600's screen is playing up, it doesn't seem to be cracked. the back light illuminates and all the buttons appear to do something (its making sounds when pressed) however there is no picture displayed. once in a blue moon he picture will come back but any tapping or movement of the screen seems to make it disappear. I think that it may be a loose connection, could you please tell me how to replace the screen?
Probably all due to a faulty flex cable that connects the screen to the main board.
I had simmilar problems so I replaced the cable and now the phone is fine.
Nick
Take the battery out, and with a small watch makers screw driver unscrew the 4 screws you see and their is another two at the end under the cover which you need to pull off. But don't worry as it sticks on.
under the bottom half there is a connection which may have come loose as its only a simple push in clip which tend to come loose.
I know the solution but its radical but hear me out Samsung know full well that this phone should be recalled its a disaster but only if we shout and scream and make the bastards hear....its called saying **** you just keep taking the dough and sitting back for a new pay day when folk meekly accept that its part of the scheme ..they make **** products we cant even buy spares for so that the after sale parasites get a pay day too Its the truth guys you know it! Danny
I have exactly the same problem with my pink sgh-u600. my screen played up for a while, flashing on & off, now it has completley gone!!
I removed the 4 screws but I can't see the the 2 others u mentioned, they're under the cover right? I can't pull the cover out, I'm scared it's attached to wires... The bottom is stuck, I'm so scared to break the phone. Please help.
Amy
Hi the problem with my phone is that none of the touch screen functions work it occasionally works and that is very occasionally. It lights up when you push the screen up but you cannot access any of the functions what could be the problem
my screen goes blank and have to keep turning it on and off to be able to see anything it does this then it just repairs itself then will go off again,
I do have the same problem with my screen i switch off my cell and remove the battery to get the screen display back it comes after this step but again goes off in few seconds..
my screen gets blank when i slide down everything gets disturbed like dialing a number or listening to a call,etc. i have repaired it once which i got the belt changed but in two weeks later the same problem i m facing. pls i want a releiable solution for my u600 mobile.
I have the same problem. the screen keeps going blank or upside down or all white or all black. I wish I'd never bought it! Should of stayed with Nokia or saved for an iphone!
