Need more info but lets try something that some times help,, make a discleanup asuming your OP is winXP goto start-all program-accesories-system tools-disc clean up-when the dialog box apear select C then in the other dialog apear check mark the boxes and click OK when finish the dicleanup goto to the same routine but select disk defragment cilck defragment... both procedure will last a lot but is the only thing that you can do be patient and reapeat those procedure regulary and your computer will run better..good luck and rate me...
There are many things that causes your pc to function slowly. one of which is that your pc might be infected by a virus. you can install an antivirus and at the same time update its virus definitions so that it can be able to clean you computer. also, your hard drive might be running out of space, all you need to do is remove unused files to free up some space. you can also check if your computer is compatible with your operating system. if your OS is new and your computer hardware is slow, then it miht cause your computer to slow down.
slow downloads wont support printer operating system not supported computer just runs slow
