Car Audio & Video Logo
Posted on Dec 12, 2009
How do I manually tune a Ford Focus 6006 Radio
How do I manually tune a Ford Focus ''6006 CD tuner'' radio, rather than scan for specific stations. I am trying to set a specific frequency manually, but the radio only seems to have a scanning option that skips frequencies.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6566
Points
6
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
Anonymous
Level 1:
New Friend:
  • Posted on May 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6566
Points
Just bought a ford cd radio,and cant tune the radio
1helpful
Additional question. How the auto scan works. I presume that pushing autoscan button tuner automatically scan given band and stops on each tuned station.
When you push the auto scan button on a radio tuner, the tuner will automatically scan through the available frequencies (also known as a "band") and stop on any station that it finds. The radio will then display the frequency or channel of the station and allow you to listen to the broadcast. The process of auto scanning can vary depending on the specific model of radio tuner that you are using, but in general it is a quick and easy way to find all of the available stations in a particular band. Some radio tuners may also allow you to save the stations that you find during the auto scan process, so that you can easily access them in the future without having to rescan.
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
I have a Blaupunkt Milano MP34 car CD Radio. I am having great problems tuning the radio into stations. Each time I try to tune in all I can get it to do is scan and it never seems to pick up any radio...
Press on the Menu key and get into Tuner list, look for this function if any.
Seek or Scan --Auto/Manual
PTY must OFF
Seek Sense --- set to high if indication is LO1,2,3 Hi 4,5,6 choose Hi 6
Cannot tune radio station manually. Only browse by band memory scan, help
Ok to set Manually Turn on radio Select Tuner select band. Press tuning mode button. The window should switch from preset to manual then tune up or down using the tuning preset time buttons left side/ top / Next to volume knob
Trying to set up satellite radio function on my clarion dxz755mc
there is more than 1 channel you can set to on sirius try setting your fm to 108 and set siriuus to same if you go into yor sirius tuner you can use the up and down arrows to tune in the stations
Cant tune radio
IS YOUR AERIAL CONNECTOR CONNECTED
4answers
Code for my FORD 6006 cd
UR RADIO CODE IS 5615 PLEASE RATE THI PLEASE THANX.
Ford Focus zx3 2002 audio question
CLOCK IS SET VIA RDS. PTY STANDS FOR PROGRAMME TYPE ITS LIKE A SEARCH ENGINE FOR RADIO STATIONS AND TA STANDS FOR TRAFFIC ANNOUNCEMENTS IF IT IS ON IT WILL TURN OVER TO LOCAL RADIO STATIONS AND GIVE YOU TRAFFIC REPORTS
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
