My sony tv has sound when you turn it on but no picture. We have unplugged the tv waited and the picture would finally come up. We called sony support and all they told us is to unplug. this morning when i got up the sound was there no picture but after cutting the tv off several times the picture appeared. now to come back home and have the same thing happen. after cont cutting off and on the picture will appear the sound is fine. the red light does not blink after the tv picture appears. when you first cut the tv on it blinks then. please help??? after the picture appears i have cut the tv off and on and the picture comes on its when you cut the tv off for a period of time there is no picture but we have sound.
Picture is gone, has sound for awhile, then the sound goes off as well. When turning on the set the screen is very bright, then goes bright blue, then black. The power light flashes five times, then stops, then repeats. Any suggestions?
My LG TV
switch on no picture but short period of sound then nothing
If the TV only has sound and no picture, consider the screen or screen line fault, you can use the replacement method to judge.
Abctay.com wholesale tv parts ,tv replament parts and more...
My sony tv has picture for couple of seconds, then it turns blue and then black but it still has sound, red light is also flashing,the timer/stand by button
Please help me find a solution to my problem
If the screen turns bright blue then you may have a bad blue crt(picture tube) I suggest an on site diagnosis by a Sony ASC to verify if it's the crt. Crt's can run up to $150.00 plus installatin and alignments.
my sony tv when i turn it on the screen is blue but then it disappears
I am having the same inssue with the tv. And my tv is the same as in this blog. Now I have no picture and no sound. And the screen turns pitch black and No signal reads at the top left hand corner of the scree.
My tv turns on fine and the picture is good for 30 secounds then starts turning blue and turns off on its own
I have the same problem did you ever get a solution?
Red light blinks 5 times
My sony tv kp53x35 ,the picture comes on for 5min and then fade away to black screen but there is sound, Thanks Harry
my sony tv has no picture but it has sound it also has a blinking light that say stand by /timer
