Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Water damage? A little bit of water got on my camera. Once I noticed, I wiped it off and tried to turn the camera on and it wouldn't. Once I got home, I charged the battery, thinking maybe that would help. I put the battery back in and now there is an orange/red light on the front of the camera that won't go away, and it still won't turn on.
    President:
  • 570 Answers
Http://www.fixya.com/support/r3771170-phone_water_damage
Posted on Jan 08, 2010
6ya staff
SOURCE:
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
Tip
How to Reset your Samsung Phone If You Can't Access It
  • Turn Off Your Phone
  • Now press and hold together: Volume Up + Home + Power button, until you see Samsung logo.
  • After a bit you will have access to the phone's boot menu. Using the volume up/down buttons to navigate, and the power button to make selections, find and select the Wipe Data/Factory Reset option.
  • Scroll down to Yes, delete all user data, and press the power button once again. You will notice script scrolling along the bottom of the screen, which will end in Data Wipe Complete.
  • Once the operation is complete, press the power button once more to reset the device.
http://www.digitaltrends.com/mobile/how-to-factory-reset-galaxy-s6
on Jul 08, 2016 | Samsung Cell Phones
Our internet works but my ipod says unable to join network. It was working a little bit ago
It could be a couple of things. It might be an issue with your WiFi router. Have you tried resetting the router? Then try reconnecting. Another issue is it could be software based. You could try first backing up your device on iTunes, and then try resetting the iPod to factory defaults by wiping it. Has the iPod been dropped or gotten wet? Check liquid indicators in the earphone jack and inside charging port. There should be a tiny white strip. If the iPod has had any water damage this strip will turn pink or red. Water damage can cause many of the functions to not work properly. Hope this was helpful
Dec 23, 2013 | Apple iPhone Smartphone
Water damage olympus vg-120
if the only your trying to fix is the screen there is a screen restoration kit you can buy for camera's almost the same thing you can for headlights on cars you will pay a little bit for it though but its def worth it and it should take about anything of your screen for you.
Jun 12, 2012 | Olympus Software VG-120 Digital Camera
I purchased a GE Z735 digital camera that turns off
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Both problems will cause the camera to shut off in order to prevent further damage, and both require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Cameras
Olympus SW 790 won't turn on after hitting the water.
Water and camera do not mix, water corrodes electrical contacts. I would suggest if you are taking a camera around water to buy one of the new water proof camera. Also salt water contact on a camera is like an acid bath. All major camera manufactures repair shops will not repair water damage.
Jul 02, 2009 | Olympus Mju 790 SW Digital Camera
Slight water damage- Sony Cybershot w-80 doesnt turn on
    Please contact any nearest SONY SERVICE CENTRE to rectify the problem.
     Thanksfor using fixya.
May 30, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Moisture inside TV
Sorry to say the info I was given here didn't prove as useful as I'd hoped. Thank you however to those who tried!!! I called a TV repair man and spoke to someone in person, this was much more useful.
Feb 02, 2009 | Televison & Video
My son sprayed our tv with a fine mist. I wiped it up once I noticed it, bit now hours later there's blackish grey streeks on the screen when I turn it on. I assume it's mosture inside the TV.. how can I...
Ok you have to unscrew the screws on the upper backpanal of the tv to access the inside of the screen(be carefull yhe mirror is connected to this panal!) one back is off wipe and c;ean inside of screen and wile its open you might as well clean the mirror and the lenses too! you will notice a better picture! now just screw panal back into place and your done! dont be scared its not hard to do at all! Now you better move it before you husband gets home!
Please rate my response!
thank you!
I got a bit of water on my sony ericsson 770i now the key pad for my numbers and texting dont work as they shoud ever thing on it is working as it shoud can it be fixed
Try holding a hair dryer to the phone for a little while... but if that doesn't help, unfortunately, water damage is irreversible in most situations. The phone will probably need to be replaced.
Apr 16, 2008 | Cell Phones
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
275 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
