Ok, the paper jam could be due to one of the following:
- Check for paper in the paper tray
- Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
- Defective D-roller
- Debris in the paper path
- Gears not turning or broken gear
- Defective paper tray
- Broken input sensor flag
- Defective input sensor board
- Defective system cable 2
- Defective system board
- Exit Sensor flag (Fuser)
- Exit Sensor board (Fuser)
- System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or
debris stuck in the rollers, it would indicate something more serious,
and in need of servicing. If your machine is under warranty, I suggest
you take it back to the shop and get it replaced.
If your warranty
has run out, then you'll either have to get it serviced or buy a new
printer (whichever works out cheaper for you)
Hope that helps!
