Two days before was printing super! Today when I try to print nothing apear. The power led and the paper feed tractor led blink together 1 time and nothing move up. When I open the cover nothing is moving also. I try to disconect power and to reconnect again. I try to reset and printing test page holding power buton and pushing four times the resume butin but nothing move. Seems to be dead. With te power boton seem to turn on and off normally. What I can do? Any idea? Thanks in advance
Buttons and lights on the printer
Two buttons and three lights are located on the front of an HP Deskjet printer.
Buttons and lights
Purpose
POWER button and light
Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on.
RESUME button and light
The light blinks when there is a problem with paper. When the problem is corrected, press the button.
Print cartridge light
The
light blinks when there is a problem with a print cartridge. When the
problem is corrected and the top cover is closed, the light will stop
blinking.
Troubleshooting blinking printer lights
Blinking lights
Reason
All The printer apear to be dead! - c00123886.jpgf.
The printer is off (asleep).
Press the POWER button
to turn the printer on.
The printer should turn on autoThe printer apear to be dead! - c00123898.jpgn a print job is sent to it.
The POWER (top) light is on.
The printer apear to be dead! - c00123900.jpgs idle.
The printer is ready to print a document.
The POWER (top) light is blinking.
The printer is busy printing.
Allow
enough time to print. When a document hThe printer apear to be dead! - c00123902.jpg or graphics or
uses complex color such as a color photo, it takes longer to begin
printing.
The PRINT CARTRIDGE (bottom) light is blinking.
Possible causes:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If
none of the above suggestions fix the problem, and, if the error
message still occurs, it may be a hardware failure. Call the HP
Customer Support Center.
http://h10025.www1.hp.com/ewfrf/wc/docum...
http://h10025.www1.hp.com/ewfrf/wc/solve...
dont work
