Nokia 7210 Logo
Posted on Dec 11, 2009
Keygaurd locked , on correct password it shows code error , it was locked while some one else entered wrong password
1helpful
Samsung Gt e 2230 m show wrong pasword on phone lock. My phone need password to turn on.
Please Follow My Solution:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 28, 2012 • Cell Phones
Sudsidy password for t mobile motorola razar
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Razor ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
You can get the Correct the subsidy password at Theunlockarena.com/motorola-razor/rs13wp9/ and Unlock it easily.Follow the instructions below and unlock it step by step...
Motorola Razor Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Razor mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Razor mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Razor with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Razor is locked to.
2answers
Phone lock not open
Possible that the lock code is faulty or it is the wrong code. Please confirm if the code was correct or if this was forgotten then the phone must be reset.Take support from Nokai care, take estimate with consensus.
I m having nokia c3.. i set its security code 123456 nd locked its keypad.. my sis tryed to open it with wrong password for 10-11 times.. wen i entered correct code its showing error.. can u suggest me...
so first switch off your phone and remove battery and sim card . and keep this for an hour. after one hour replace your sim card and battery on the phone . now switch on the phone and enter the same security code again this will now work. keep smile. have a nice day
Jun 19, 2011 • Cell Phones
1helpful
2answers
How to unlock the nokia x2-01 security keyguard if i have forgotten the password
i have not changed my phone's security code since i set it when the phone was new. i had also set the security keypad lock on,and it worked well till recently when i tried to unlock the keypad but it kept showing me the 'code error' banner. IMEI:358615046174564. phone model is Nokia X2-01. Please help to reset the code.
Jun 16, 2011 • Cell Phones
I have a nokia 5310set.I havn't changed any of the default settings.But when i tried to set the security keygaurd facility its showing error?What is the default code for this set?
Usually,the default code for nokia mobile is 12345,if you didn't change it before or if you bought your mobile as brand you,maybe you enter a wrong key for several times and the result will be counter blocked.
Try this method.
* Turn off your mobile for 1 hour
* Turn it on and try to enter the code
1. the default code is 12345
2. enter your desire code if your change it before.
good luck...
Hi, I am using Nokia 6300 model phone. Some days back i activated the "Keypad lock with security code". Last day my friends were just working on it and they entered the wrong code for many times(I...
HEY HI....
THIS IS NOT A BIG DEAL,JUST DROP UR MOBILE IN THE NEAREST NOKIA SHOW ROOMS OR NOKIA CARE AND THEY WILL REINSTALL THE SOFTWARE.....NOTHING T0 WORRY......
THANK YOU...GOOD DAY....
How to unlock my nokia 5220 phone..even if i type the correct password...its showing code error
If you enter the wrong password for more than 5 times,it will ask you for your PUK code(the code error as you have referred to it).Call your network supplier and ask
for the PUK(its free), enter the password to your phone thats it problem fixed.
If you had locked your phone then update the formware all saved passwords will be deleted.
3helpful
2answers
Fujitsu Siemens AMILO Pro V2000 PC Notebook what default BIOS password My computer is locked
there is no default bios password
all i know at the some fujitsu laptops if you enter 3 times wrong bios password the computer locks
This is a security issue
13helpful
4answers
Forgot the key gaurd lock code
Try 12345 or visit http://www.unlockme.co.uk/master.php
Enter your imei number to generate master reset code.
Cheers. rate fixya
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
