Please be careful when using free unlock services as you may run the risk of having your phone hardlocked.
Hardlocked, as a technical term, means that your phone cannot be SIM unlocked anymore.
A phone can be hardlocked for so many reasons. It could be:
The last reason happens when you have used up all the unlock attempts.
To check your phone it is being hardlocked, read through here : What's A Hardlocked Phone? What We Know So Far
No, since free blackberry storm unlock code not reliable and can make your phone hardlocked. The best way to get reliable blackberry unlock code is from your network provider or purchase at third parties sites on internet.
Www.unlockbb.com has them, not FREE but good prices.
SOURCE: unlocking my blackberry storm
It's a clear and fully detailed guide on how to unlock a BlackBerry Storm (95XX) :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
SOURCE: blackberry locked to telus network
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry Storm.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
SOURCE: want to unlock my verizon blackberry storm 9530 free codes
It's a clear and fully detailed guide on how to unlock a BlackBerry Storm :
3. Go to Options
5. Select SIM Card
8. Type MEP2 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter network mep code
11. Enter the code ( you should see "code accepted" )
All done.
