Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on Dec 11, 2009
LCD monitor is damaged. Is there any way to fix it replace?
How to fix white horizontal lines on middle of screen of a PC monitor?
Need to check removing LCD ribbon cable in the monitor. but it is may be a damage of LCD screen ,need to replace the lcd.but in very first check and service the lcd.
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
I have asus Vh192d and there is a two straight lines, please tell me how to remove this two lines
Anytime you have straight lines on an LCD monitor, it indicates damage/failure in the LCD panel itself. The only fix is to replace the LCD panel.
There is a large scratch on the screen, and appears black when the monitor is on. My monitor fell and hit the edge of a shelf because I had it leaning forward too much. Obviously, the mark is deep, and the...
It is evident that the LCD panel of the monitor is damaged. If your computer has Dell complete care you can get the monitor replaced. If not you can contact a local technician and get the LCP panel changed, with the remaining circuit boards and backlight assembly intact.
2helpful
My Problem w/ my Toshiba Satellite P105-S9337 model no. PSPAGU - OOJOOV is it has a strip of white line vertical on the screen and it's about 1" thick? is their a way I can fix this problem?
Connect an external monitor to the VGA port on the computer. If that display is correct, then it's probably the LCD screen on your laptop that is damaged.
Find a computer-store. They may have "pre-owned" LCD screens the same size, for about $100.
A "brand-new" LCD screen is at least $200.
Replacing the LCD screen is *NOT* something that *YOU* can fix, unless you're a qualified technician.
2helpful
Screen on my mobile Tv is damage can it be fixed
You can replace the screen as a whole but, you will have to send it to a diesel audio repair terminal for this repair. the actual LCD replacement part is not available for consumer purchase.
1helpful
2 thin vertical line on lcd monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
If you keep pushing it in and out you may damage another one and make another line.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
Sorry there isn't an easy fix to this.
Fran
1helpful
I damaged the screen on my dell 1901FP monitor there is a large black area in the middle of the screen, however, you can see the icons and the screensaver behind the large black area. Is there any way to...
After the damage the LCD panel had developed an internal liquid crystal leak.
The only way to fix the monitor is by replacing the LCD display panel, this is an expensive part and must be ordered from Dell.
2answers
Could my laptop screen be leaking?
Sounds like the LCD has sustained physical damage. Replacement is the normal solution.
Monitor Mike
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
