I installed the software and connected the camera to my windows microsoft XP according to the user guide but the computer cannot detect the camera connection
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: conecting thr camera to my computer
@keren:
That error message somehow means your USB connector wasn't plugged in properly to the camera. Another thing is that windows xp doesn't have driver for your camera that's why it wasn't recognized. what's the brand of your camera though? If you just want to transfer your pix from camera to pc or vice versa, use a card reader like the guy above me said.
SOURCE: Camera window keeps telling me that the camera is not detected
How about try these again
1- Uninstall all of the software related to Canon.
2- Install the drivers for your Canon ONLY.
3- After installing the drivers, plug your camera to a different USB port. (test your USB is working okay by connecting another USB device)
4- TURN YOU CAMERA ON
5- The drivers for your camera will be installed.
6- After it is finished, click start, then computer. Now you should have one Icon starting with canon.....
If you see this icon, double click on it. You will find one or more folders which contain the pictures stored in your camera. You may now download, delete Etc.
You either have not done above steps correctly, or your cable or your USB port is bad.
Good Luck!!!!!!
